Re: low oil pressure
Posted by Bruce(OR) on August 16, 2018 at 10:52:34 [URL] [DELETE] :
In Reply to: low oil pressure posted by michael mix on August 14, 2018 at 17:08:04:
Syn oil is too thin to run until you get the OP up. OP is effected by bearing clearances when warm. That OP dropping to 5 PSI, yikes. If you have no metal in the pan, I would be looking at the OP mounting or the OP itself. If you had shavings in the oil, a tear down should be performed. For oil, I run the old diesel grade 15/40.
The heavy duty oil that has zinc in it to keep the flat tappet cams from going bad.
15/40 might be a bit thick, but her machine generally does not get used in the dead of winter.
