low oil pressure
Posted by michael mix on August 14, 2018 at 17:08:04 [URL] [DELETE] :
62 ford 841 engine has about 5 psi oil pressure at idle when the engine is warm, the oil pressure is 25psi at 1500 rpm, the engine has new bearings properly installed at .002 clearance. the engine has the g-rotor pump. any suggestions. thanks mike
