Re: Position control interesting problem?
Posted by K.LaRue-VA on August 13, 2018 at 20:00:37 [URL] [DELETE] :
In Reply to: Position control interesting problem? posted by Dead Eye Dave on August 11, 2018 at 10:19:10:
Once you get the lift problem fixed, or even if you don't, save a bunch of wear and tear on the hydraulics and cutter by hanging the cutter on a set of limiter chains.
Once I set the correct cutting height with the chains, the hydraulic touch control lever just stays down until it's time to swap implements.
