Re: 9n Distributor not the problem
Posted by Bruce (VA) on August 10, 2018 at 14:08:46 [URL] [DELETE] :
In Reply to: Re: 9n Distributor not the problem posted by David on August 10, 2018 at 13:39:43:
OK, now I'm totally lost.
You said you can feel compression when you turn the engine over....
And now you say it's locked up tight.
Which is it?
If the engine is locked up, it won't create compression.
