Re: 9n Distributor not the problem
Posted by JMOR on August 09, 2018 at 17:32:09 [URL] [DELETE] :
In Reply to: Re: 9n Distributor not the problem posted by David on August 09, 2018 at 17:21:47:
"Biggest mistake so far was buying this tractor". You mean you are not married? :)
OK, the crankshaft turns the camshaft via gears between the two. The slot in end of camshaft turns the distributor. If crankshaft turns (pulley/belt/fan) but not camshaft, then likely that cam gear has missing teeth.
