Re: 9n Distributor not the problem
Posted by David on August 09, 2018 at 17:21:47 [URL] [DELETE] :
In Reply to: Re: 9n Distributor not the problem posted by JMOR on August 09, 2018 at 15:56:42:
If I am to assume that the crank turns the distributor
the slot in the shaft has not moved once and remained in the same position
for a long time
I never did get the points to open and close checked the power on the top of coil and that is where I read 6.27 or so volts but when cranked it dropped to 5.7 volts so I guess they were opening and closing never got the half voltage you all said I should get
I am no mechanic never touched a motor only to change fluids and filters all of this is a mystery to me so if I get some things wrong that is why
biggest mistake so far was buying this tractor
