Re: 9n with Dearborn 19-81 loader
Posted by Lynn on August 07, 2018 at 20:44:02 [URL] [DELETE] :
In Reply to: Re: 9n with Dearborn 19-81 loader posted by mhb@ufe on August 07, 2018 at 19:07:03:
Thanks for the info Mark. Do you have any suggestions as to how to lock down the lift arms. I have had this tractor for several years and only used the blade. Now I have some projects where I want to use the loader. When I was using the blade I just used the manual valve to shut off hydraulic fluid to the bucket cylinders. What it sounds like to me is that you either use the bucket or the blade but not both at the same time.
