Re: Re
Posted by David on August 06, 2018 at 13:25:15 [URL] [DELETE] :
In Reply to: Re: Re posted by Bruce (VA) on August 06, 2018 at 12:34:53:
the last time I checked with these same components that I set the same way as I had them for these tests the voltage at the top of coil was 5.27 and when cranking the starter it dropped to 5.7 at the lowest
these were set with the proper timing and the proper gap checked numerous times
I had no spark at the plugs with new plugs gapped at .03 and new plug wires
