Re: Mystery 3-hole Whatsit
Posted by K.LaRue-VA on July 31, 2018 at 23:31:12 [URL] [DELETE] :
In Reply to: Re: Mystery 3-hole Whatsit posted by mhb@ufe on July 31, 2018 at 16:01:19:
Yep, hit the nail, Thanks! Once you provided the name, it was easy to find in the parts book (with the clutch parts). Seems like I should have remembered taking that out when I removed the flywheel. I'm baffled why they decided a retainer was necessary. Maybe this was an assembly plant issue, where some pilot bearings got knocked out and lost before the transmission was attached to the engine. Once the tranny pilot shaft goes into the pilot bearing, there is absolutely no way that bearing can go anywhere.
