Re: 9n Distributor
Posted by HCooke on July 30, 2018 at 08:41:21 [URL] [DELETE] :
In Reply to: Re: 9n Distributor posted by David on July 30, 2018 at 07:52:36:
This is critical to diagnosing your no spark problem. Another way to to this is to attach a test light to the top of the coil and ground it somewhere. When the ignition is on the light should glow. When you crank the engine with the ignition on, the light should alternately glow light and dim. This shows that your points are working. Do this and report back.
