Re: 9n Distributor
Posted by HCooke on July 28, 2018 at 16:28:08 [URL] [DELETE] :
In Reply to: Re: 9n Distributor posted by David on July 28, 2018 at 15:13:19:
Forget your generator and charging circuit for now. That has absolutely nothing to do with your no spark condition. The tractor should start and run fine (for a while) even if the generator isn't working. Several people have asked if you have battery voltage at the top of the coil with the ignition switch on and the points closed. It should drop to half that much when the points close.
