Re: 9n Distributor
Posted by HCooke on July 27, 2018 at 17:37:31 [URL] [DELETE] :
In Reply to: 9n Distributor posted by David on July 27, 2018 at 15:49:18:
Get you your multi tester and set it on resistance. Ground one lead to the case. Attach the other lead to the brass screw at the top of the distributor. With the points open there should be infinite resistance (the meter should not move). With the points closed there should be no resistance (the meter should peg out).
Try this and post back.
