Re: 641 - gas in oil (again)
Posted by BlasterStumps on July 25, 2018 at 21:17:46 [URL] [DELETE] :
In Reply to: 641 - gas in oil (again) posted by Mike in Michigan on July 25, 2018 at 18:14:50:
I suppose I deserve to be roasted for suggesting this but, might look at putting an inline shut off in the gas line. I have one in the line on my NAA. I put a new fuel shut off valve and sediment bowl in the tank but it leaks. New stuff is mostly crap if it comes from some place else. The inline valve is just a brass valve 1/4" or so. When I shut the tractor down, I turn the fuel shutoff valve off and then go around on the other side and turn the 1/4 brass valve off. I wait until the engine starts to sputter a little then I turn the key off. I might still get a drip at the fuel shutoff valve but at least the carb doesn't fill up and cause the gas in oil problem.
Ok guys, let me have it. : )
