641 - gas in oil (again)
Posted by Mike in Michigan on July 25, 2018 at 18:14:50 [URL] [DELETE] :
I rebuilt the carb a few times and again have gas in the crankcase. I turn the gas off after each use by turning the screw directly beneath the tank.
The 75 Tips paper says "The fuel shut-off valve on the sediment bowl is there for a reason...".
Is there a difference where the fuel needs to be turned off?
