Axle bearing cup/bearing installation
Posted by Jeff on July 25, 2018 at 16:09:43 [URL] [DELETE] :
Bought a new rear axle and bearing. I'm going to try seating the bearing on the axle myself by freezing the axle and heating the bearing then forcing on with PVC pipe, wood block and a hammer. I saw this method in another forum. As for the new bearing cup, will the same method work? Freeze the cup, heat the retainer, wood block and a hammer. Is this feasible?
