Re: 9n Camshaft Gear
Posted by BlasterStumps on July 24, 2018 at 20:24:33 [URL] [DELETE] :
In Reply to: 9n Camshaft Gear posted by Kevin on July 24, 2018 at 18:00:31:
The recommendations I have seen on the fiber gear is to change the camshaft and gear to the newer style with bolt on gear. It might be possible to take that old fiber gear off but getting it back on in perfect time, might be a bit tough. If you go to the newer gear, you should be able to line up the timing fairly easily. I have not done this so don't know all the ins and outs to doing it.
Mike
