Re: 9n woes
Posted by HCooke on July 17, 2018 at 17:41:48 [URL] [DELETE] :
In Reply to: 9n woes posted by David on July 17, 2018 at 16:45:04:
Attach one lead from a test light to the post and the top of the coiol and attache the other lead to a good ground. Turn the ignition key on. It should light up. Now with the ignition on crank the motor. Light should alternate between bright and dim. Do this and report back.
