9n woes
Posted by David on July 17, 2018 at 16:45:04 [URL] [DELETE] :
ok so I tested all the different parts
the ignition,coil,battery,starter solenoid and I have no spark
I pulled a plug put the wire back on and held it to the frame while
trying to start no spark...
I should see spark correct?
I did test at the top of coil and have 6.3 something volts but when I tried to test the plugs going into the distributor I got no reading at all
should I have gotten 6 there as well
I am at a loss its not gas I have gas flowing out the bottom of the carb
Help!!
