Re: Hydraulic lift lever assembly
Posted by Dave2N on July 16, 2018 at 18:19:33 [URL] [DELETE] :
In Reply to: Re: Hydraulic lift lever assembly posted by r geiger on July 16, 2018 at 09:35:59:
I have a 1943 2N that has war era characteristics, it has a cast lever. My project 1946 has a punched out steel lever. The 43 is my go to Working Tractor. I lost the hydraulics on a road maintainence project, and wanted to swap out hydraulics. The punched out Steel lever looked damaged where it rests the cylinder. Ended up pulling the top cover from the 43, and bringing home for a rebuild.. After dismantling the top cover there is heavy pitting on rock shaft, Do I have to replace it ?
