Re: Follow-up on Daughters 2N
Posted by Del Huebner on July 16, 2018 at 13:30:30 [URL] [DELETE] :
In Reply to: Follow-up on Daughters 2N posted by Del Huebner on July 13, 2018 at 10:03:00:
Here is what I did with the analog meter. Checked the battery with engine at half throttle it registered 6V. Checked the generator it registered 7.4V. Checked the Gen. lead at the cut-out it registered 7.4V. Checked the Bat. terminal at the cut-out it registered 6V. Used a jumper wire from Bat. to Gen. on cut-out like Harold suggested and the Amp gauge read charging about 8 amps. Checked the Battery again while amp gauge was charging and it was still 6V. Appears the new cut-out is bad and something else wrong. All connections on the battery have been cleaned.
