Re: Carburetor
Posted by dave #1 on July 13, 2018 at 04:42:21 [URL] [DELETE] :
In Reply to: Carburetor posted by Theo Morris on July 12, 2018 at 04:35:35:
Good to have you aboard !
It's been said that sometimes your running problems are not your carburetor but a weak ignition that needs more gas in order to run (Choke on)??
Now I have had 2 cases where I had running problems on 2 different N's that were carburetor related , both cases I removed the carburetors, disassembled, cleaned with carburetor cleaner and high pressure air, all ports that I could see were open and clean, installed the carburetors and they didn't run any better, I ended up switching carburetors with a good running tractor and that fixed the problem, I bought 2 Taiwan build Carburetors and fixed both tractors .
For what it's worth.
later,dave
