Re: Carburetor
Posted by BlasterStumps on July 12, 2018 at 04:37:26 [URL] [DELETE] :
In Reply to: Carburetor posted by Theo Morris on July 12, 2018 at 04:35:35:
There are supposed to be up to 3 screens in the fuel system. One on top of the fuel shutoff inside the tank, one in the sediment bowl of the fuel shutoff, and one in the elbow going into the carb. I would make sure they are all clean and that you have good flow to the carb. There should be a plug on the bottom of the fuel bowl of the carb. If you remove that plug, it should run a steady stream. Also, if I am remembering correctly, the tank has a vent hole that can be plugged.
