ford 9n
Posted by David on July 10, 2018 at 21:38:19 [URL] [DELETE] :
I have been having issues with my 1942 Ford 9n
have talked and posted here and have gotten many helpful tips on my problem of the tractor not starting
I installed a new carb and adjusted it and had my tractor running for a bit and even managed a bit of work out of it but now it died again and did not start
I have been through the wiring which by all diagrams I have seen is no where near what it should be
my biggest concern is it has a negative ground and by most all I have read on the wiring it should have a positive ground
Should I switch this to a positive ground or leave it as is because it was running before
I have a new harness on the way and a new ignition tune up kit and relay with a new keyed ignition
so far I have replaced the carb and the plugs inspected the distributor and there is a small crack it the housing for the distributor
