Re: 8n starter brushes
Posted by Bruce (VA) on July 07, 2018 at 12:30:54 [URL] [DELETE] :
In Reply to: 8n starter brushes posted by Jim Dicharry on July 07, 2018 at 10:44:07:
Next time, check out tip # 36 before you pull the starter.
And, do check out tip # 52 before you mess w/ the Bendix.
There are plenty of ways to put the starter back together. Some folks use alligator clips, toothpicks or dental floss to hold the brushes back. Others remove the metal band and paper gasket, then put the starter back together. Pull the brushes up thru the holes that the band was covering. Use long nose pliers to pull the brush springs up. Move each one to the right and let them rest on the brush holder. Put each brush into the holder. Pull up each spring and place it on each brush. Put the gasket and metal band back on.
