Re: Rotary cutter wobble
Posted by Frank (WNY) on July 05, 2018 at 10:05:04 [URL] [DELETE] :
In Reply to: Re: Rotary cutter wobble posted by K.LaRue-VA on July 05, 2018 at 07:51:20:
Thanks for the information. The metal on this King Kutter doesn't look that bad. Most of the paint is good and there isn't a lot of rust. The blades don't look like they have seen much use. The stump jumper looks pretty solid. I am hoping my impact wrench will vibrate the nuts loose. I am waiting for some new seals to come so I can stop the leaking. I am going to try to chain the deck up against a tree to get the stump jumper off to replace the output shaft seal.
I appreciate the advice.
