Re: Rotary cutter wobble
Posted by Frank (WNY) on July 04, 2018 at 09:35:38 [URL] [DELETE] :
In Reply to: Re: Rotary cutter wobble posted by K.LaRue-VA on July 04, 2018 at 07:44:32:
That is another reason that I need to get the blades off. Both are either rusted solid to the stump jumper or the bolts are tightened to the point where neither can swing. I knew this before I started, but thought that once I started, they might break loose. they are both stuck straight out from the center. The blades had surface rust on them, cutting an acre cleaned them up. The are not sharp but look like they both have had little use. I don't think they have ever been sharpened before.
