Re: 8N running rough
Posted by Jeff on July 01, 2018 at 18:59:46 [URL] [DELETE] :
In Reply to: Re: 8N running rough posted by Tim Daley(MI) on July 01, 2018 at 07:40:26:
I just checked the entire wiring harness and compared it to JMOR's wiring pictograms. I also checked all connections for continuity. Everything is in order.The only difference is this tractor was switched to a Negative ground. Why would that be? What's the point? Should I just go ahead and switch back to positive? As far as I can tell it's as simple as grounding the positive cable and running the negative to the solenoid connection. Am I missing something here? Will I have to re-polarize the generator if I switch?
