NAA rear differential housing leak
Posted by Ken on June 30, 2018 at 12:41:35 [URL] [DELETE] :
Hello,
I have a 1953 NAA. It has been in the family for close to 50 years. Prior to that it was used by a swimming pool company. They had a backhoe attachment on it. This resulted in the rear differential housing developing some cracks. I don't think there's a real structural issue. It just causes the gear oil to leak. Over the years attempts have been made to fix the cracks by brazing or filling with epoxy. Nothing has worked to completely seal it.
This wasn't much of an issue for years and it was just a very slow leak of gear oil. Over the past 10 years we have started using the tractor for more and more things and the leak has increased. I'm probably having to add a gallon of gear oil every couple weeks.
Last week I was running the brush hog with the tractor and the left side lower link support pin for the 3 point hitch snapped off. It appears that to replace this I'll need to remove the axle trumpet.
From what I can tell this should give me some access to the inside of the differential housing. I'm thinking this would be a good opportunity to try and seal the cracks. I would imagine there is some product I could apply to the cracks from the inside. Does anyone have thoughts about what I could use? Any thoughts would be appreciated.
Thanks,
Ken
