Re: 850 starves for fuel
Posted by Tim Daley(MI) on June 27, 2018 at 05:03:37 [URL] [DELETE] :
In Reply to: 850 starves for fuel posted by Nickq83 on June 26, 2018 at 16:20:04:
"...on hot days it stops getting gas I open the fuel cap and bubbles are coming into the tank from the fuel line....". Bubbles not likely coming from fuel line, most likely the gas is boiling in the tank. Ensure other items are correct -rerouting the fuel line probably didn't do anything and really not needed. Heat shield in place? Is the correct carb installed? Tank dirty and/or vent plugged? Install a vented gas cap. The debate goes on whether the 10% ethanol mix gasoline today is the root cause of gas boiling, and you can search the archives here for all the past discussions on that so I'm not going to go into it here. There are many opinions, facts and fallacies, and much discussion on that. Some claim non-ethanol gas is the solution, but I'm from Missouri so 'show me the data'. In other words, check all the usual items first and don't just assume because someone said that was the fix, they are right.
