Re: Vapor lock on Ford 600
Posted by Jack - Iowa on June 26, 2018 at 16:24:40 [URL] [DELETE] :
In Reply to: Vapor lock on Ford 600 posted by Charles on June 26, 2018 at 08:27:03:
Charles,
If the 600 is built like the 860 you may have a gas line location problem. Put a new gas line on my 860. It runs down between the engine block and the exhaust manifold. If it gets too close to that manifold you will have a problem which I would call vapor lock. Space the gas line in the center or slightly closer to the engine block.
If it walks like a duck, quacks like a duck, it likely is a duck!
Jack
