2N Dilema
Posted by Del Huebner on June 26, 2018 at 12:14:01 [URL] [DELETE] :
My daughter has a 46 2N with a Woods belly mower. When she mows it will run for about an hour or so and suddenly quit. It will not start back up until it sits for about 15 minutes then will start back up. She lives about 15 miles from our place so by the time I get out there to look at it everything is fine and it starts right up. I did change out the key switch and replaced the non-vented gas cap with a vented one. It has spark and gas flow when I check it. When she mows again its the same thing ,shutting down and no start. Is there anything I can check without being there when it shuts down? She says it also seems to lose power on a uphill grade. Any help here would be appreciated. Thanks
