Re: Fuel shut off valve.
Posted by Frank (WNY) on June 26, 2018 at 11:57:02 [URL] [DELETE] :
In Reply to: Re: Fuel shut off valve. posted by AL CT on June 26, 2018 at 11:29:46:
I just installed a new one from Just8N's a few weeks ago. The nut at the bottom of the bail took a lot of tightening to get it to seal. I used the neoprene one that came with it. I had a new cork one, but if I have a reason to take the bowl off again I will probably replace it with that one. Check around the nut on gas line going to the carb. if that weeps it makes the bowl look like it is leaking.
