Re: Oil
Posted by gary starr on June 25, 2018 at 22:12:17 [URL] [DELETE] :
In Reply to: Oil posted by Tony C on June 25, 2018 at 12:27:02:
Water oily water not mixed in,dipstick clean clear oil ran no more than 15 minutes. I knew what antifreeze does that's why I used plain water until I solve this. Got about a pint of water out of the filter. Did not notice any cracks in head or block since old gasket was stuck and had to clean off with a razor blade. Did not check head since there was no overheat. One thing I did notice is that one cylinder liner seemed to stand proud of the block enough for the razor blade to catch on it while cleaning. Any studs that came out when I removed the head I used sealer on when I put them back in. Hope it's not terminal,I just looked at the engine cast date it is 1-5-7
