Re: Generator Bushing Removal
Posted by BlasterStumps on June 23, 2018 at 21:35:53 [URL] [DELETE] :
In Reply to: Generator Bushing Removal posted by Owen H on June 23, 2018 at 21:05:59:
pack the hole of the bushing with heavy grease. Then take a bar with a very close OD to the hole size, place it on the grease inside the bushing and wack it with a hammer. The bar pushes the grease in behind the bushing forcing the bushing out. You could also tap threads in the bushing and insert bolt and pull it out.
Neither idea are mine.
Mike in CO
