Re: 600 Fuel Shut-off valve
Posted by 36 coupe on June 18, 2018 at 19:58:42 [URL] [DELETE] :
In Reply to: Re: 600 Fuel Shut-off valve posted by Gary Puckett on June 17, 2018 at 17:58:46:
You can fix the original valve with a new oring.The alumnium stop pin is replaced with a 10/32 hex head screw.MMO will eat original o rings.The original valve was made by Bendix aviation.Tank has to come off to replace the O ring.Dont remove the valve body from the tank.
