Re: 53 three point wont lift
Posted by Doug on June 15, 2018 at 06:24:22 [URL] [DELETE] :
In Reply to: Re: 53 three point wont lift posted by JMOR on June 13, 2018 at 12:58:22:
ok so my dad and i tried to prime the pump by adding air to the chamber, no luck. we tried bleeding air from the pump be loosening the pipe plug on the pump. i went a little too far with the plug and out it came. needless to say the pump is working, my dad and i got soaked. we are going to pull the top plate this weekend. i know the back pressure line in mine goes directly into the return, that is the way it was when we took it apart. we will change that, i have a different cylinder we may try and see if that is the problem. it just seems that no oil is getting to the control.
