Cranking but no start
Posted by John on June 13, 2018 at 09:51:09 [URL] [DELETE] :
Hey guys, as always thanks for your incredible knowledge and help. I have a 53 Jubilee that was last ran over thanksgiving of 2017 where she ran like a charm. I did NOT disconnect the battery over the winter months. When I first attempted to start the tractor it sounded like it was going to turn over on the first push, unfortunately that was not the case. The tractor did not start, but is cranking as normal. Might the battery be the problem, even though the engine is cranking? Side note, when I last used the tractor the fuel sediment bowl where you turn the knob was leaking fuel at a good drip. Is it possible that fuel has been drained from the system, if so, any suggestions on how to remedy? Thanks youin advance!
John
