Re: 1952 8n 3pt hydraulics failure
Posted by Bruce (VA) on June 12, 2018 at 11:40:17 [URL] [DELETE] :
In Reply to: Re: 1952 8n 3pt hydraulics failure posted by Cole on June 11, 2018 at 21:12:51:
" Arms do chatter a big t going up tho"
When the N lift is jerky coming up it means that one or more of the four pump cylinders is not pumping. It can be caused by broken springs in the pump chambers or a broken Scotch yoke in the pump that the pistons are attached to. Either one means the pump will need to be removed from the tractor to fix.
