Re: Ford NAA Golden Jubilee 1953 - over heating
Posted by Tim Daley(MI) on June 11, 2018 at 04:06:44 [URL] [DELETE] :
In Reply to: Ford NAA Golden Jubilee 1953 - over heating posted by Rusty on June 10, 2018 at 19:08:52:
You should always use a thermostat. Often overheating is caused by overfilling or underfilling. Is it original 6V/POS GRN or a 12V switchover job? Either way, have you checked the fan belt tension? Do you have the correct fan belt? Often times 12V jobs use the wrong fan belt. Does the radiator leak?
