Re: Gasoila E-Seal
Posted by Frank (WNY) on June 10, 2018 at 14:28:40 [URL] [DELETE] :
In Reply to: Gasoila E-Seal posted by Frank (WNY) on June 08, 2018 at 09:40:43:
So far so good! No leaks around the bottom of the gas tank where the shutoff valve is threaded in. When I opened the valve, there was a leak where the plug goes into the back and around the inlet to the elbow filter in the carb. I cranked down on both several times until the leaking stopped. Keep your fingers crossed...
