Re: Gasoila E-Seal
Posted by Tim Daley(MI) on June 08, 2018 at 17:31:00 [URL] [DELETE] :
In Reply to: Gasoila E-Seal posted by Frank (WNY) on June 08, 2018 at 09:40:43:
Yes, I have used this stuff now for several years since firs discovering it. I have a pint jar that will last me a lifetime. I only use it on the Fuel Sediment Bulb NPT Male end that threads into the gas tank. Best results are to have an empty tank first. Clean parts that will mate. Apply GASOILA compound to male end and screw into female end. Be sure it is set where you want it. I keep the fuel shutoff valve facing out as designed for easy access. Let it set for a few days minimum. Once it dries it is safe to assemble fuel line and try out. I did my 8N years ago now and have had zero problems since. I have not used it on the brass elbow carb inlet or any other NPT threads. Carb elbow gets removed to clean now and then. With the diffy plug I just apply a dab of clean hydraulic oil on the male threads. Makes it easier to remove when changing hydraulic fluid. I do not use TEFLON tape, white or yellow on my tractor fuel lines. GASOILA is designed to work with gas, ethanol blended or otherwise. As Mike Nesmith said, I'm a Believer and I endorse GASOILA 100%...
GASOILA:
