Re: Advice on ball joint lower lift arm
Posted by r geiger on June 03, 2018 at 12:30:43 [URL] [DELETE] :
In Reply to: Advice on ball joint lower lift arm posted by Kimberly on June 03, 2018 at 12:23:58:
I have a fair amount of play between the ball and the lift arms, but the fit between the stud on implement to the ball should be fairly tight if you have the correct class one set up.
