Advice on ball joint lower lift arm
Posted by Kimberly on June 03, 2018 at 12:23:58 [URL] [DELETE] :
I am not up on all the parts name. I got an original leveling arm off of fleabay ($55.00 with shipping). I removed the lower lift arm (that connects to the plough, etc) and I am going to take everything over to my brother-in-law to press out the bolt/pin so I can install the replacement leveling arm. The ball joint on the lower lift arm where it attaches to the axle is rather worn but the ball is still retained. My question is about the amount of play between the hole in the ball and the stud that the hole slips onto. Should there be a large amount of play between the hole in the ball and the stud? I saw a video on YouTube where someone put a bushing in to take up the play.
I am including a photo of the leveling arm I got off of fleabay.
