Re: No start
Posted by Dave2N on May 28, 2018 at 21:41:37 [URL] [DELETE] :
In Reply to: Re: No start posted by Tim Daley(MI) on May 28, 2018 at 17:19:21:
After many hours of bonding with The Ole Girl. After removing distributor twice and inspecting wiring, replacing coil wire, tightening all wires on ballast resistor. Two trips to TSC. There on the starter button ( positive feed to ignition switch) was a corroded terminal. Cut it back and replaced end. Fired right up.
