Re: Electrical harness, ignition problems
Posted by Jim In Montana on May 23, 2018 at 13:39:52 [URL] [DELETE] :
In Reply to: Electrical harness, ignition problems posted by Marty on May 22, 2018 at 16:16:26:
Be sure and check and clean every terminal and connection point. Make sure they are clean and bright. Clean with wire brush or sand paper. Check your battery cables and make sure they are clean where they attach. Any corrosion can cause a break, and stop you cold.
Also, several have mentioned, and i will join them, be SURE it is in Neutral before trying any of these tests as you try to start it. Many have been hurt or killed as they WILL start in gear.
Good luck,
