Re: Electrical harness, ignition problems
Posted by R Geiger on May 23, 2018 at 08:53:12 [URL] [DELETE] :
In Reply to: Re: Electrical harness, ignition problems posted by Marty on May 23, 2018 at 07:38:41:
If you still have your old solenoid, I would try it. New parts have been known to be bad. assume you have a small wire hooked to the solenoid on the same post as the battery cable. I have heard of solenoids being wired wrong so that the small terminal would have to face away from the block tho.
It really sounds like you have it wired correctly.
