Re: Electrical harness, ignition problems
Posted by Marty on May 23, 2018 at 07:38:41 [URL] [DELETE] :
In Reply to: Re: Electrical harness, ignition problems posted by R Geiger on May 22, 2018 at 17:50:59:
I think I have everything as you described. The red wire from the push button goes to the inboard terminal of the solenoid (there is only one small terminal). The push button will not push unless its in neutral. The ignition switch, wiring harness and solenoid are all brand new, and the starter was bought last year. When running jumper cables from the battery to the starter, it turns the engine over. I have to have it wired wrong for some reason. There's only 5 wires!! I'm a little baffled at this point....
