Re: 860 pto clutch
Posted by SteveVa on May 18, 2018 at 12:27:11 [URL] [DELETE] :
In Reply to: 860 pto clutch posted by lonestarjeff on May 16, 2018 at 17:53:00:
You may need some load on it to get it to come loose. Sounds like it may well be stuck to the flywheel. I have heard of folks finding a hole to spray some break cleaner in there to get things loose. Is the 860 like the Jubilee where the hydrolic pump runs off the fly wheel. You might be able to expose things there. Good luck with it, be careful...
