6 volt positive ground?
Posted by James Mort on May 16, 2018 at 14:28:08 [URL] [DELETE] :
Im new to this, is this tractor 6 volt positive ground? Serial number on the block is 9N105085, it has a generator. The PO had a 12 volt battery in it hooked up to negative ground. I started it by jumping straight to the starter. It took right off and ran but I want to make it original. The POs son told me the battery was always dead.
