Re: Compression test
Posted by Rusty 2N on May 15, 2018 at 08:54:37 [URL] [DELETE] :
In Reply to: Re: Compression test posted by Tim Daley(MI) on May 15, 2018 at 04:09:54:
It is back together. Set up a temp. fuel tank and changed exhaust to get the stack out of my way. Removed carb. Changed needle and seat with a new one and reset the float. Will do more after I get back from town later today. Fingers crossed!!!
These old girls take time and $$ and patience to get them defarmerized or refarmerized in some cases and dependably.
Running a stack exhaust cause steering box leaks onto exhaust and this is dry land wheat country. One spark or heat from pipe and many acres turn black real fast!!! Scary fast!!! Will change back to stock when leak is fixed. Which is next on the list when she gets running again. Box feels good but needs some adjusting and deleaked.
Same process as the 2n went through over the years.
Have a good day!!! Rusty
